Introducción
Replace the cable on your MacBook Core Duo that connects the upper case to the logic board.
Herramientas
Partes
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
Carefully peel the upper case cable off the adhesive securing it to the upper case.
33 personas más completaron esta guía.
Un Comentario
Andrew you are the best.Very easy to follow instructions.I will replace mind,90 points
