Saltar al contenido principal
Desmontaje de la pantalla inferior de Nintendo DS Lite
Inglés
Español
Paso 2
Nintendo DS Lite Lower Screen Replacement: paso 0, imagen 1 de 2 Nintendo DS Lite Lower Screen Replacement: paso 0, imagen 2 de 2
  • Locate the small ribbon cable that connects the touch screen to the motherboard. Do not pull on this cable.
  • Gently lift the hinged black cover on the connector.
  • The hinges are near where the ribbon is inserted.
  • After lifting the black cover, the ribbon cable will disconnect easily.
Localiza el pequeño cable plano que conecta la pantalla táctil a la placa lógica. No tires de este cable.
Levanta con cuidado la cubierta negra con bisagras del conector.
Las bisagras están cerca de donde se inserta la cinta.
Después de levantar la cubierta negra, el cable plano se desconectará fácilmente.
-[* red] Locate the small ribbon cable that connects the touch screen to the logic board. Do not pull on this cable.
-[* green] Gently lift the hinged black cover on the connector.
-[* black] The hinges are near where the ribbon is inserted.
+[* red] Locate the small ribbon cable that connects the touch screen to the motherboard. Do not pull on this cable.
+[* orange] Gently lift the hinged black cover on the connector.
+[* icon_note] The hinges are near where the ribbon is inserted.
[* black] After lifting the black cover, the ribbon cable will disconnect easily.
