Saltar al contenido principal
iBook G4 Reemplazo de teclado de 14 "933 MHz-1.33 GHz
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 22 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
iBook G4 14" 933 MHz-1.33 GHz Keyboard Replacement: paso 0, imagen 1 de 1
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again. The locking screw is in between the F5 and F6 keys and is a clear piece of plastic.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Tire de las pestañas de liberación del teclado hacia usted y levante el teclado hasta que se libere.
Si el teclado no se suelta, use un destornillador plano pequeño para girar el tornillo de bloqueo del teclado 180 grados en cualquier dirección y vuelva a intentarlo.
Da la vuelta al teclado, lejos de la pantalla, y recuéstelo boca abajo en el área del trackpad.
[* black] Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
-[* icon_note] If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
+[* icon_note] If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again. The locking screw is in between the F5 and F6 keys and is a clear piece of plastic.
[* black] Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
