Saltar al contenido principal
Elgato Stream Deck MK.1 Screen Replacement
Inglés
Español
Paso 7
Elgato Stream Deck MK.1 Screen Replacement, Seperate the button grid: paso 0, imagen 1 de 3 Elgato Stream Deck MK.1 Screen Replacement, Seperate the button grid: paso 0, imagen 2 de 3 Elgato Stream Deck MK.1 Screen Replacement, Seperate the button grid: paso 0, imagen 3 de 3
  • The button press-detecting grid thingy is a small thin plastic cover gently glued to the corners of the screen.
  • Gently peel it back from the screen to separate them. If there's any remaining sticky tape residue on the grid, peel it off.
  • Set the grid aside for later.
  • You have successfully liberated your damaged screen from the rest of the construction 🎉. Time to put it all back together again.
Insertar traducción aquí
