Saltar al contenido principal
Elgato Stream Deck MK.1 Screen Replacement
Inglés
Holandés
Paso 5
Elgato Stream Deck MK.1 Screen Replacement, Seperate the circuit board: paso 0, imagen 1 de 3 Elgato Stream Deck MK.1 Screen Replacement, Seperate the circuit board: paso 0, imagen 2 de 3 Elgato Stream Deck MK.1 Screen Replacement, Seperate the circuit board: paso 0, imagen 3 de 3
  • Being mindful of all the connections, lift the circuit-board out entirely of the chassis so you can access the ribbon connectors.
  • Peel off the insulator tape above the connectors.
  • Disconnect each ribbon cable. The middle connector and the wide connector both have latches that lift/hinges upwards to release the cable. The remaining connector pulls forwards slightly.
Insertar traducción aquí
