Saltar al contenido principal
RazorX DLX Electric Skateboard Control Module Replacement
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 5
RazorX DLX Electric Skateboard Control Module Replacement: paso 0, imagen 1 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 0, imagen 2 de 3 RazorX DLX Electric Skateboard Control Module Replacement: paso 0, imagen 3 de 3
  • Remove the 20 mm Phillips #0 screw.
  • Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
  • Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
  • Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
  • A hall effect sensor is used to tell the board where the motor is in its rotation.
  • You will need to remove silicone and hot glue to remove the connectors.
Insertar traducción aquí
