Introducción
This guide is intended to show you how to replace the control module on the RazorX DLX Electric Skateboard. This guide may apply to later models of this skateboard as well. The control module communicates with the users remote control in order for the skateboard to properly function. When handling the control module, be careful with the wires and avoid any damage to the circuit board. Before you start, make sure the power button is switched to off.
Qué necesitas
Flip the skateboard upside down.
Use a 4 mm Allen key to remove the 25 mm bolt that secures the cover.
Push the cover forward to slide it off.
Flip the skateboard back over.
Remove the six 22 mm bolts indicated on the top side of the skateboard with a 3 mm Allen key.
While holding the nut from the underside of the skateboard remove the four 32 mm bolts with the 3 mm Allen key.
Separate the trucks and control module from the board.
Remove the 20 mm Phillips #0 screw.
Disconnect the DC connector. The DC connector can be identified as the connector with only two wires.
Disconnect the power button. It is a temporary switch, which can be identified by its 4-wire configuration.
Disconnect the Hall effect sensor. It can be identified by its 6-wire configuration.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
