Traduciendo paso 6
Paso 6
Disassembling the supporting structure
The torch is connected to a supporting structure which is attached to the base of the lamp. It had an LED strip around it which was removed with tweezers, and had wire connections to the PCB board.
The PCB board was stuck, and so the connection point had to be cut with a pair of scissors.
The structure itself was difficult to separate, because there was a unique and complicated hook type twisting mechanism, which could only be undone via damaging the hooks.
Height: 65 mm
Width: 90 mm
Weight: 24 g
