Saltar al contenido principal
Alienware M11xR3 Disassembly and Cleaning
Inglés
Español
Traduciendo paso 35
Paso 35
Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: paso 0, imagen 1 de 3 Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: paso 0, imagen 2 de 3 Alienware M11xR3 Disassembly and Cleaning, Remove heat sink and apply thermal paste: paso 0, imagen 3 de 3
  • If this is your first time applying thermal paste, I recommend using a quality thermal paste brand like Arctic Silver and reading a guide here on iFixit.
  • With the motherboard out, turn it upside down on a static free surface.
  • To remove the heatsink and replace thermal paste, remove the screws in the correct order (marked with a number on the heatsink).
  • Clean old thermal paste with isopropyl alcohol. Ensure that after applying thermal paste it doesn't leak onto the motherboard (if it's on the green square, it's fine).
  • When putting the heat sink back on, try to have the screw holes align on your first try. This is to maintain an even spread of the thermal paste.
  • Rescrew in the correct order (refer to the numbers on the heat sink).
  • Tighten each screw one at a time to end up with good heat dissipation.
Insertar traducción aquí
