Saltar al contenido principal
Reemplazo de la batería de Kobo Libra Colour
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
Kobo Libra Colour Battery Replacement, Battery information: paso 0, imagen 1 de 1
Battery information
  • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery! A punctured battery can leak dangerous chemicals and catch fire.
  • If your battery comes with stretch release adhesive, follow the next two steps to remove them.
  • Otherwise, skip ahead two steps to remove the normal adhesive.
Cuando trabajes en la batería o cerca de ella, ¡no utilices herramientas metálicas para evitar pincharla y provocar un cortocircuito! Una batería perforada puede derramar sustancias químicas peligrosas e incendiarse.
Si tu batería viene con adhesivos de liberación elástica, sigue los dos pasos siguientes para retirarlos.
De lo contrario, salta los dos pasos siguientes para retirar el adhesivo normal.
[title] Battery information
-[* icon_caution] When working on or near the battery, ***don't use metal tools*** to avoid puncturing and shorting the battery! A punctured battery can leak dangerous chemicals and catch fire.
+[* icon_caution] When working on or near the battery, ***don't use sharp metal tools*** to avoid puncturing and shorting the battery! A punctured battery can leak dangerous chemicals and catch fire.
[* red] If your battery comes with stretch release adhesive, follow the next two steps to remove them.
[* black] Otherwise, skip ahead two steps to remove the normal adhesive.
