Saltar al contenido principal
Cómo usar el Anti-Clamp en superficies difíciles
Inglés
Español
Paso 2
How to Use Suction Tape, Measure the tape: paso 0, imagen 1 de 3 How to Use Suction Tape, Measure the tape: paso 0, imagen 2 de 3 How to Use Suction Tape, Measure the tape: paso 0, imagen 3 de 3
Measure the tape
  • Measure the length of tape you want and mark it with a pen. Consider the following:
  • You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
  • Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
Mide la longitud de cinta que quieras y márcala con un bolígrafo. Considera lo siguiente:
Necesitas suficiente cinta para las ventosas del Anti-Clamp. No dejes huecos, o las tazas no se pegarán.
No uses demasiada cinta para que se doble sobre los bordes de tu teléfono. Esto puede interferir con el procedimiento de apertura.
[title] Measure the tape
[* black] Measure the length of tape you want and mark it with a pen. Consider the following:
- [* red] You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
+ [* red] You need enough tape for the [product|IF145-513|Anti-Clamp]'s suction cups. Don't leave gaps, or the cups won't stick.
[* orange] Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
