Saltar al contenido principal
TicWatch Pro 3 GPS Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Holandés
Paso 3
TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: paso 0, imagen 1 de 2 TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: paso 0, imagen 2 de 2
Pry up the battery
  • The battery is held in place by mild adhesive.
  • Insert the flat end of a spudger between the bottom edge of the battery and the midframe.
  • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  • Pry upwards to loosen the battery.
  • If you're struggling to pry up the battery, place a heated iOpener onto the motherboard to loosen the adhesive underneath. Don't apply the iOpener directly onto the battery.
  • Don't try to remove the battery all the way yet. It's still connected to the motherboard.
Insertar traducción aquí
