Saltar al contenido principal
Front Panel Assembly Removal
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 15 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 7
Paso 7
Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 1 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 2 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 3 de 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Insertar traducción aquí
