Saltar al contenido principal
Remoción del conjunto del Panel Frontal
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 1 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 2 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 3 de 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Remueve el conjunto del panel frontal.
Usa una púa de apertura para cortar cualquier adhesivo residual que podría estar conectando el conjunto del panel frontal al marco.
Si experimentas toques "fantasma" en tu nueva pantalla, esto puede ser resuelto aplicando una capa muy fina de cinta aislante, como la cinta Kapton (poliamida), en las áreas marcadas en la parte trasera del panel. Los digitalizadores de reemplazo de iFixit vienen con la aislación adecuada y no deberían requerir la adición de cinta.
Sin la aislación correcta, estas áreas del digitalizador pueden hacer contacto con otros componentes, causando mal funcionamiento de la entrada táctil.
La aislación no es visible a simple vista, y es diferente de las tiras de espuma anti-polvillo presentes en la mayoría de los iPads.
Durante el reensamblaje, antes de instalar una pantalla, remueve cualquier resto de adhesivo del iPad, y limpia estas áreas con alcohol isopropílico altamente concentrado (90% o más) y un paño libre de pelusa. Esto ayuda a preparar el iPad para el adhesivo nuevo, asegurando que se pegue adecuadamente.
Prueba las funciones de tu iPad e instala las tiras adhesivas pre-cortadas a la parte trasera de la pantalla usando nuestra guía de aplicación de adhesivo antes de sellarlo.
