Saltar al contenido principal
Verwijderen van de voorste paneelmodule
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 7
Paso 7
Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 1 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 2 de 3 Front Panel Assembly Removal, Remove the front panel assembly: paso 0, imagen 3 de 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Verwijder de voorste paneelmodule.
Gebruik een openingsplectrum om de overige lijm, die de voorste paneelmodule nog steeds aan het frame van de iPad bevestigt, door te snijden.
Als je bij je nieuwe scherm last hebt van "spook-" of "fantoom"aanrakingen kun je dit probleem verhelpen door een laag zeer dunne isolatietape, zoals Kapton (polyimide) tape aan te brengen op de gemarkeerde gebieden op het achterste paneel. iFixit-digitizers bevatten deze isolatie al, waardoor deze stap overbodig is.
Zonder de juiste isolatie kunnen deze gebieden van de digitizer contact maken met andere onderdelen, waardoor de touch-functies van je scherm niet goed zullen functioneren.
De isolatie is niet zichtbaar met het blote oog en is niet hetzelfde als de schuimstrips die je in veel iPad's vindt.
Zorg dat je, bij het weer in elkaar zetten van je toestel, eerst alle oude lijmresten uit de iPad verwijdert met wat isopropyl alcohol (>90%) en een pluisvrije doek voordat je je nieuwe scherm plaatst. Dit maakt je iPad klaar voor het plaatsen van nieuwe lijm en een goede hechting.
Test de functies van je iPad en bevestig vervolgens de vooraf op maat gesneden kleefstrips aan de achterkant van je scherm met behulp van onze handleiding voor het aanbrengen van kleefstrips.
