Saltar al contenido principal
Dell XPS 15 9560 Touchpad Replacement
Inglés
Holandés
Paso 5
Dell XPS 15 9560 Touchpad Replacement: paso 0, imagen 1 de 2 Dell XPS 15 9560 Touchpad Replacement: paso 0, imagen 2 de 2
  • Gently pull the white ribbon cables out from their housings. To disconnect, use a spudger or your fingernail to gently lift the looped tab away from the connector. It should pop up easily.
  • Next, use the spudger or your fingernail to push the plastic tab away from the socket. It should move slightly.
  • Now, pull the white ribbon cables out.
Insertar traducción aquí
