Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Traduciendo paso 3
Paso 3
Separate the casing
Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
Carefully separate the gray outer casing of the control port and the circuit board.
[title] Separate the casing | |
+ | [* icon_note] This step may not be necessary depending on your end goal |
[* red] Use a Phillips #2 screwdriver to remove the two screws on the back of the control port. | |
[* orange] Carefully separate the gray outer casing of the control port and the circuit board. |
