Introducción
Removing these panels allows further access to the GameCube's components.
Herramientas
Partes
No se especificaron partes.
Turn over the Gamecube so that the bottom side is facing up.
Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
Gently press down on the clips located on either side of the the back panel, as shown, and carefully remove it from the main part of the device.
4 personas más completaron esta guía.
