Saltar al contenido principal
HP Spectre x360 15-bl012dx Battery Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 2
HP Spectre x360 15-bl012dx Battery Replacement: paso 0, imagen 1 de 3 HP Spectre x360 15-bl012dx Battery Replacement: paso 0, imagen 2 de 3 HP Spectre x360 15-bl012dx Battery Replacement: paso 0, imagen 3 de 3
  • Please note the upper two feet are already removed. The device was given to us this way.
  • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
  • Remove the two 8 mm Phillips #1 screws under the feet.
  • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
Insertar traducción aquí
