Saltar al contenido principal
HP Spectre x360 15-bl012dx Battery Replacement
Qué necesitas
  1. HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: paso 1, imagen 1 de 2 HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: paso 1, imagen 2 de 2
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx Battery Replacement: paso 2, imagen 1 de 3 HP Spectre x360 15-bl012dx Battery Replacement: paso 2, imagen 2 de 3 HP Spectre x360 15-bl012dx Battery Replacement: paso 2, imagen 3 de 3
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx Battery Replacement: paso 3, imagen 1 de 1
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx Battery Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx Battery Replacement: paso 5, imagen 1 de 3 HP Spectre x360 15-bl012dx Battery Replacement: paso 5, imagen 2 de 3 HP Spectre x360 15-bl012dx Battery Replacement: paso 5, imagen 3 de 3
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
Conclusión
2 personas más completaron esta guía.
Peyton Stewart
Miembro Desde 02/22/22
300 Reputación
2 Guías creadas
Equipo
Clemson, Team 1-1, Hunter Spring 2022 Miembro de Clemson, Team 1-1, Hunter Spring 2022
CLEM-HUNTER-S22S1G1
5 Miembros
5 Guías creadas
7 comentarios
Great writeup. Any idea where I could get an OEM or OEM-quality replacement battery?
Ben - Contestar
Excellent guidance, many thanks!
Brenda Mallinson - Contestar
Thanks for the guide! Figured there were screws under the rear feet but this confirmed it and prevented me from doing something silly.
Nick Di Vona - Contestar
Where are you guys finding replacement batteries from? I don't want to go through the process of buying and returning crappy batteries
Kisan Patel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 3,939
