Saltar al contenido principal
Reemplazo del Altavoz Anki Cozmo
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
Anki Cozmo Speaker Replacement: paso 0, imagen 1 de 2 Anki Cozmo Speaker Replacement: paso 0, imagen 2 de 2
  • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
  • There are four white hubcaps removed in this step. If your Cozmo is a different color, the hubcaps will also be the same color.
Retira el tapacubos blanco de cada una de las cuatro ruedas usando el spudger de metal para quitarlas.
En este paso se retiran cuatro tapacubos blancos.
[* black] Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
-[* icon_note] There are four white hubcaps removed in this step.
+[* icon_note] There are four white hubcaps removed in this step. If your Cozmo is a different color, the hubcaps will also be the same color.
