Traduciendo paso 8
Paso 8
Heat your soldering iron up to 350 degrees celsius.
The two pins you need to desolder will be diagonal of each other.
At this point, you want to desolder both pins holding the switch. As the solder is being melted you want to use your desoldering pump to remove the solder that has been melted.
