Saltar al contenido principal
Desmontaje de Dell Vostro V13
Inglés
Español
Traduciendo paso 1
Paso 1
Dell Vostro V13 Disassembly: paso 0, imagen 1 de 3 Dell Vostro V13 Disassembly: paso 0, imagen 2 de 3 Dell Vostro V13 Disassembly: paso 0, imagen 3 de 3
  • Remove the two plastic dummy cards from the laptop.
  • Unscrew the six PH00 screws from the bottom of the laptop.
  • Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
  • Slide the bottom cover forward and lift it upwards to remove.
  • You may need to use a strong spudger to create a gap along the base edge - starting from the Ethernet port on the right toward the Kensington port on the left.
Retire las dos (2) tarjetas falsas de la computadora portátil.
Con un destornillador Phillips, desatornille los seis (6) tornillos de la parte inferior de la computadora portátil.
Desenrosque los dos (2) tornillos de la parte posterior de la computadora portátil, ubicados en el extremo izquierdo y derecho del panel posterior.
Deslice la cubierta inferior hacia adelante y levante hacia arriba para extraerla. Es posible que necesite usar un spudger fuerte para forzar un espacio a lo largo del borde de la base desde el puerto de Ethernet a la derecha, hasta el puerto kensington a la izquierda.
-[* blue] Remove the two (2) dummy cards from the laptop.
-[* red] Using a Phillips head screwdriver, unscrew the six (6) screws from the bottom of the laptop.
-[* blue] Unscrew the two (2) screws from the back of the laptop, located at the extreme left and right of the back panel.
-[* blue] Slide bottom cover forward and lift upwards to remove. You may need to use a strong spudger to force a gap along the base edge from the ethernet port on the right, to the kensington port on the left.
+[* red] Remove the two plastic dummy cards from the laptop.
+[* orange] Unscrew the six PH00 screws from the bottom of the laptop.
+[* yellow] Unscrew the two PH00 screws from the back of the laptop, located at the extreme left and right of the back panel.
+[* black] Slide the bottom cover forward and lift it upwards to remove.
+ [* icon_note] You may need to use a strong spudger to create a gap along the base edge - starting from the Ethernet port on the right toward the Kensington port on the left.
