Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará la guía que incluye este paso.
Traduciendo paso 2
Paso 2
Open the back cover
Try to use a thin tool like a razor blade to start to pry open the back cover.
When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
