Saltar al contenido principal
Nokia 3.1 Battery Replacement
Qué necesitas
  1. Nokia 3.1 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Battery Replacement, Open the back cover: paso 2, imagen 1 de 3 Nokia 3.1 Battery Replacement, Open the back cover: paso 2, imagen 2 de 3 Nokia 3.1 Battery Replacement, Open the back cover: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Plastic Cards
    $2.99
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Battery Replacement, Remove logic board cover: paso 3, imagen 1 de 2 Nokia 3.1 Battery Replacement, Remove logic board cover: paso 3, imagen 2 de 2
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Battery Replacement, Remove battery adhesive strips: paso 4, imagen 1 de 2 Nokia 3.1 Battery Replacement, Remove battery adhesive strips: paso 4, imagen 2 de 2
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
Conclusión
To reassemble your device, follow these instructions in reverse order. Also don’t forget some double-faced adhesive tape to fixate the new battery.
9 personas más completaron esta guía.
Baschtl
Miembro Desde 12/02/12
1,608 Reputación
5 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 7,618
