Saltar al contenido principal
Tado Smart Radiator Thermostat v3 Plus Teardown
Inglés
Español
Paso 3
Tado Smart Radiator Thermostat v3 Plus Teardown, Removing the Main Electronics: paso 0, imagen 1 de 1
  • The single PCB is secured with 2 cross head screws and a ribbon cable which leads to the "display".
  • By lifting the tightening cover of the ribbon cable you can remove it.
  • By removing the 2 standard screws you can finally completely remove the PCB from the assembly.
  • Pay attention to the before mentioned cogwheel. It will also fall out.
  • Additionally there are two plastic pins which transfer button pushes from to the PCB. More for that to come when looking at the PCBs.
Insertar traducción aquí
