Saltar al contenido principal
Tado Smart Radiator Thermostat v3 Plus Teardown
Inglés
Español
Paso 2
Tado Smart Radiator Thermostat v3 Plus Teardown, Getting into the Shell: paso 0, imagen 1 de 3 Tado Smart Radiator Thermostat v3 Plus Teardown, Getting into the Shell: paso 0, imagen 2 de 3 Tado Smart Radiator Thermostat v3 Plus Teardown, Getting into the Shell: paso 0, imagen 3 de 3
  • Removing the cover which has the "tado" logo embossed is the first step to getting into the thermostat.
  • It is secured with 3 clips.
  • One right next to the little opening for the temperature sensor .
  • Two other on the opposite side.
  • Once you removed the cover you can easily pry off the serrated ring. This serration is connected to a little cogwheel which transfers the turning motion to an electrical signal for setting the temperature.
Insertar traducción aquí
