Saltar al contenido principal
Sustitución de la Tarjeta Wifi del Toshiba Satellite E105-S1602
Inglés
Español
Paso 2
Toshiba Satellite E105-S1602 Wifi Card Replacement: paso 0, imagen 1 de 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: paso 0, imagen 2 de 3 Toshiba Satellite E105-S1602 Wifi Card Replacement: paso 0, imagen 3 de 3
  • Locate the black wire and white wire connected to the WiFi card.
  • Using a pair of tweezers remove the wires by lifting them straight up away from the board.
  • For reassembly, note that the black wire connects to the top port, and the white wire to the bottom part.
Localiza el cable negro y el cable blanco conectados a la tarjeta WiFi.
Usando un par de pinzas, retira los cables levantándolos hacia arriba de la placa.
Para volver a ensamblar, ten en cuenta que el cable negro se conecta al puerto superior y el cable blanco a la parte inferior.
[* red] Locate the black wire and white wire connected to the WiFi card.
-[* black] Using a pair of tweezers remove the wires by lifting them straight up away from the board.
+[* black] Using a pair of [product|IF145-020|tweezers] remove the wires by lifting them straight up away from the board.
[* icon_note] For reassembly, note that the black wire connects to the top port, and the white wire to the bottom part.
