Saltar al contenido principal
Sustitución de la Placa de Contacto del Botón Frontal del Mando de la Nintendo Switch Pro
Inglés
Español
Traduciendo paso 1
Paso 1
Nintendo Switch Pro Controller Front Button Replacement, Unscrew front button board: paso 0, imagen 1 de 1
  • Use a Phillips screwdriver to remove the 5 mm-long screw securing the front button board.
  • There may be an additional screw. If so, remove it now.
Utiliza un destornillador Phillips para quitar el tornillo de 5 mm de largo que sujeta la placa de botones frontal.
[title] Unscrew front button board
-[* black] Use a Phillips screwdriver to remove the 5 mm-long screw securing the front button board.
+[* red] Use a Phillips screwdriver to remove the 5 mm-long screw securing the front button board.
+[* orange] There may be an additional screw. If so, remove it now.
