Saltar al contenido principal
Reemplazo de la batería del iPhone 11
Inglés
Español
Paso 9
iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): paso 0, imagen 1 de 3 iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): paso 0, imagen 2 de 3 iPhone 11 Battery Replacement, Removing a stuck battery (alternate method): paso 0, imagen 3 de 3
  • If your battery is stuck and an appropriate liquid solvent is not available, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch, but no more.
  • Flip the iPhone back over and thread a strong piece of string (such as dental floss) underneath the battery.
  • Wear gloves to protect your fingers, or wrap each end of the string around a tool.
  • Pull the string from side to side in a sawing motion to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
  • Start from the top or bottom edge of the battery, and pull toward the middle. Don't pull the string through the middle third of the battery, or you may damage the ribbon cables or the wireless charging coil directly underneath.
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
Si alguna de las tiras adhesivas se rompió y la batería permanece pegada a la caja trasera, prepara un iOpener o usa un secador de pelo para calentar la caja trasera directamente detrás de la batería.
Calienta el iPhone hasta que la caja trasera esté un poco demasiado caliente para tocarla cómodamente, pero no más.
Vuelve a dar la vuelta al iPhone y enrosca un trozo de cuerda fuerte (como el hilo dental) debajo de la batería.
Usa guantes para proteger tus dedos, o envuelve cada extremo de la cuerda alrededor de una herramienta.
Tira de la cuerda de un lado a otro con un movimiento de sierra para separar el adhesivo. Esto puede llevar algún tiempo ya que el adhesivo se deforma lentamente, pero con paciencia se liberará. No deformes o dañes la pila.
Empieza por el borde superior o inferior de la batería y tira hacia el centro. No tires de la cuerda por el tercio medio de la batería, ya que podrías dañar los cables de la cinta o la bobina de carga inalámbrica que está directamente debajo.
Si decides utilizar herramientas de palanca para sacar la batería del iPhone, ten mucho cuidado o puedes dañar los cables de cinta o la bobina de carga inalámbrica que se encuentran directamente debajo de la batería.
