Saltar al contenido principal
Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement
Inglés
Español
Traduciendo paso 3
Paso 3
Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: paso 0, imagen 1 de 3 Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: paso 0, imagen 2 de 3 Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: paso 0, imagen 3 de 3
  • Use the black spudger to remove the last remaining wire ribbon plug on the motherboard, located on the side facing the plastic frame.
  • Remove the 2mm #00 Phillips head screw on the lower left corner of the motherboard. The motherboard should now lift free from the plastic frame.
Insertar traducción aquí
