Saltar al contenido principal
Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement
Inglés
Español
Paso 2
Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: paso 0, imagen 1 de 3 Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: paso 0, imagen 2 de 3 Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: paso 0, imagen 3 de 3
  • Remove one 2mm #00 Philips head screw from the bottom of the camera frame. This will free the lens and motherboard from the frame.
  • Be careful not to completely remove the metal frame, there is still a small wire ribbon attached.
  • Gently separate the metal frame from the lens assembly just enough to reach the wire ribbon on the front side of the camera.
  • Use the rubber tipped tweezers to unplug the wire ribbon.
  • Remove the metal frame and slide the lens motor assembly out of the plastic frame.
Insertar traducción aquí
