Saltar al contenido principal
Solucion de problemas/Remplazo de Tarjeta SD de Nintendo 3DS
Inglés
Español
Traduciendo paso 3
Paso 3
Nintendo 3DS SD Card Replacement / Troubleshooting, Find the problem: paso 0, imagen 1 de 1
Find the problem
  • Now it's time to really look into things. First suspect is the SD card. Slip it into a PC and see if it can detect the SD card.
  • Is it blank? Does it refuse show up? If so, there is probably an issue with the card itself. See if you can find/buy a spare one, and copy over any backup you may have made beforehand.
  • Does the computer read the SD card? It may be time to crack it open and replace the SD card reader.
  • If you're really squeamish about cracking things open before knowing for sure, try another SD card in the 3DS. The card you're using may just be faulty.
Ahora es el momento de realmente mirar las cosas. El primer sospechoso es la tarjeta SD. Deslízala en una PC y mira si puede detectar la tarjeta SD
¿Está en blanco? ¿Se niega a aparecer? Si es así, probablemente haya un problema con la tarjeta en sí. Mira si puedes encontrar/comprar una de repuesto, y copia en ella cualquier copia de seguridad que hayas hecho de antemano.
¿La computadora lee la tarjeta SD? Puede ser hora de abrirlo y reemplazar el lector de la tarjeta SD.
Si realmente te preocupa abrir cosas antes de estar seguro, prueba con otra tarjeta SD en la 3DS. Es posible que la tarjeta que estás utilizando esté defectuosa.
[title] Find the problem
-[* black] Now it time to really look into things. First suspect is the SD card. Slip it into a PC and see if it can detect the SD card.
+[* black] Now it's time to really look into things. First suspect is the SD card. Slip it into a PC and see if it can detect the SD card.
[* orange] Is it blank? Does it refuse show up? If so, there is probably an issue with the card itself. See if you can find/buy a spare one, and copy over any backup you may have made beforehand.
[* orange] Does the computer read the SD card? It may be time to crack it open and replace the SD card reader.
[* icon_note] If you're really squeamish about cracking things open before knowing for sure, try another SD card in the 3DS. The card you're using may just be faulty.
