Saltar al contenido principal
Solucion de problemas/Remplazo de Tarjeta SD de Nintendo 3DS
Inglés
Español
Paso 2
Nintendo 3DS SD Card Replacement / Troubleshooting, SD card checks: paso 0, imagen 1 de 2 Nintendo 3DS SD Card Replacement / Troubleshooting, SD card checks: paso 0, imagen 2 de 2
SD card checks
  • Another pretty simple step: check that the card isn't locked. There should be a small switch at the side of the card which, shockingly, says "lock". Make sure the switch is the farthest away that it can be from that word, and you're good to go.
  • If the system tells you that the card is locked when it shouldn't be, use tape to hold down the lock switch securely.
  • While we're doing that, also look for any dirt or dust on the SD card or in the slot. If there is, try cleaning it with a soft cloth, or blowing it out with some compressed air.
Otro paso bastante sencillo: verifica que la tarjeta no esté bloqueada. Debería haber un pequeño interruptor al costado de la tarjeta que, sorprendentemente, dice "bloquear". Asegúrate de que el interruptor esté lo más lejos posible de esa palabra y listo.
Si el sistema te dice que la tarjeta está bloqueada cuando no debería estarlo, use cinta adhesiva para mantener presionado el interruptor de bloqueo de forma segura.
Mientras hacemos eso, también busca suciedad o polvo en la tarjeta SD o en su ranura. Si lo hay, intenta limpiarlo con un paño suave o soplándolo con un poco de aire comprimido.
[title] SD card checks
[* red] Another pretty simple step: check that the card isn't locked. There should be a small switch at the side of the card which, shockingly, says "lock". Make sure the switch is the farthest away that it can be from that word, and you're good to go.
[* orange] ***If the system tells you that the card is locked when it shouldn't be, use tape to hold down the lock switch securely.***
-[* icon_reminder] While we're doing that, also look for any dirt or dust on the SD card or in its slot. If there is, try cleaning it with a soft cloth, or blowing it out with some compressed air.
+[* icon_reminder] While we're doing that, also look for any dirt or dust on the SD card or in the slot. If there is, try cleaning it with a soft cloth, or blowing it out with some compressed air.
