Saltar al contenido principal
Inglés
Español
Paso 4
Slide an opening pick back and forth across the bottom edge of the phone in the gap you created to cut the adhesive holding the screen in place. If you plan to re-use this screen, be careful not to insert your opening pick more than 3 mm here to avoid damaging the LCD under the glass. If you plan to re-use this screen, be careful not to insert your opening pick more than 3 mm here to avoid damaging the LCD under the glass.
  • Slide an opening pick back and forth across the bottom edge of the phone in the gap you created to cut the adhesive holding the screen in place.
  • If you plan to re-use this screen, be careful not to insert your opening pick more than 3 mm here to avoid damaging the LCD under the glass.
Desliza una púa de apertura hacia adelante y hacia atrás a través del borde inferior del teléfono en el hueco que creaste para cortar el adhesivo que mantiene la pantalla en su lugar.
Si planeas reutilizar esta pantalla, ten cuidado de no insertar aquí tu púa de apertura más de 3 mm para evitar dañar la pantalla LCD debajo del cristal.
