Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 5
Slide the opening tool back and forth across the bottom edge of the phone, cutting through the adhesive securing the rear glass panel. Once the adhesive is cut and the gap is wide enough, insert an opening pick into the gap to keep the adhesive from re-bonding. Remove the opening tool. Once the adhesive is cut and the gap is wide enough, insert an opening pick into the gap to keep the adhesive from re-bonding. Remove the opening tool.
  • Slide the opening tool back and forth across the bottom edge of the phone, cutting through the adhesive securing the rear glass panel.
  • Once the adhesive is cut and the gap is wide enough, insert an opening pick into the gap to keep the adhesive from re-bonding. Remove the opening tool.
Desliza la herramienta de apertura hacia adelante y hacia atrás a través del borde inferior del teléfono, cortando a través del adhesivo que asegura el panel de cristal trasero.
Una vez que el adhesivo esté cortado y el espacio sea lo suficientemente ancho, inserta una lengüeta de apertura en el espacio para evitar que el adhesivo se vuelva a pegar. Retira la herramienta de apertura.
