Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 4
To make this step easier, you can prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick, like an eraser. This will angle the phone so that the opening tool is easier to insert. If you don't have a small object for propping, you can (carefully) perform this step at the edge of a desk or table to achieve the same angle of entry. Lift the rear panel's bottom edge with your suction cup, opening a slight gap between the panel and the frame.
  • To make this step easier, you can prop up the heated edge of the phone on something that is about 0.5 inches (13 mm) thick, like an eraser. This will angle the phone so that the opening tool is easier to insert.
  • If you don't have a small object for propping, you can (carefully) perform this step at the edge of a desk or table to achieve the same angle of entry.
  • Lift the rear panel's bottom edge with your suction cup, opening a slight gap between the panel and the frame.
  • This may require a significant amount of force. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
  • Once you've created a gap, press the flat end of an opening tool into the gap.
  • The rear glass panel is fragile and can break if you use too much force or attempt to pry with metal tools.
Para facilitar este paso, puedes apoyar el borde calentado del teléfono sobre algo que tenga aproximadamente 13 mm de grosor, como una goma de borrar. Esto inclinará el teléfono para que la herramienta de apertura sea más fácil de insertar.
Si no tienes un objeto pequeño para apuntalar, puedes (cuidadosamente) realizar este paso en el borde de un escritorio o mesa para lograr el mismo ángulo de entrada.
Levanta el borde inferior del panel trasero con la ventosa, abriendo un pequeño espacio entre el panel y el marco.
Esto puede requerir una cantidad significativa de fuerza. Si tienes problemas, aplica más calor para ablandar aún más el adhesivo e inténtelo de nuevo. El adhesivo se enfría muy rápido, por lo que es posible que tengas que calentarlo repetidamente.
Una vez que hayas creado un espacio, presiona el extremo plano de una herramienta de apertura en el espacio.
El panel de cristal trasero es frágil y puede romperse si se utiliza demasiada fuerza o se intenta hacer palanca con una herramienta metálica.
