Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 42 guías que incluyan este paso.
Inglés
Español
Paso 8
Take the first pick you inserted and slide it up toward the top corner of the iPad. If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off. If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Toma la primera púa que insertaste y deslízala hacia arriba en dirección a la esquina superior del iPad.
Si puedes ver la punta de la púa de apertura a través del vidrio frontal, no te asustes, simplemente tira de la púa un poco. Lo más probable es que todo esté bien, pero trata de evitar esto ya que puede depositar adhesivo en la parte frontal de la pantalla LCD que es difícil de limpiar.
