Saltar al contenido principal
Extracción de panel de cristal trasero del LG G6
Aviso: Ahora estás editando un requisito previo de la guía que estabas viendo. Cualquier cambio que realices afectará a todas las 8 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 10
Paso 10
LG G6 Rear Glass Panel Removal: paso 0, imagen 1 de 1
  • If reusing the rear glass panel during reassembly:
  • Use tweezers to peel away any remaining adhesive from both the rear panel and the phone's chassis.
  • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
  • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
  • Peel away the replacement adhesive's liner, align it with the back of the phone, and press it into place.
  • Remove any remaining liners, and replace the rear glass panel.
  • After installing the rear panel, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  • You can also reinstall the rear panel without replacing the adhesive. Remove any large chunks of adhesive that might prevent the panel from sitting down flush. After installation, heat the panel and apply pressure to secure it. The phone won't be waterproof, but the residual adhesive is usually more than strong enough to hold.
Si vuelves a usar el panel de cristal trasero durante el reensamblaje:
Utiliza pinzas para quitar cualquier resto de adhesivo del panel trasero y del chasis del teléfono.
Limpia las zonas de adherencia con alcohol isopropílico de alta concentración (al menos el 90%) y un paño sin pelusas. Desliza el dedo en una sola dirección, no hacia atrás y hacia adelante. Esto ayudará a preparar la superficie para el nuevo adhesivo.
Asegúrate de encender el teléfono y probar tu reparación antes de instalar adhesivo nuevo y volver a sellar el teléfono.
Retira el revestimiento del adhesivo de repuesto, alinéalo con la parte posterior del teléfono y presiónalo en su lugar.
Retira los revestimientos restantes y vuelve a colocar el panel de cristal trasero.
Después de instalar el panel trasero, aplica una presión fuerte y constante al teléfono durante varios minutos para ayudar al adhesivo a formar una buena unión, por ejemplo, colocándolo debajo de una pila de libros pesados.
También puedes instalar el panel trasero sin reemplazar el adhesivo. Retira cualquier trozo grande de adhesivo que pueda impedir que el panel se siente al ras. Después de instalarlo, calienta el panel y aplica presión para fijarlo. El teléfono no será impermeable, pero el adhesivo residual suele ser lo suficientemente fuerte como para sostenerse.
