Saltar al contenido principal
iPad Mini CDMA LCD Assembly Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 42 guías que incluyen este paso.
Inglés
Holandés
Paso 11
iPad Mini CDMA LCD Assembly Replacement: paso 0, imagen 1 de 3 iPad Mini CDMA LCD Assembly Replacement: paso 0, imagen 2 de 3 iPad Mini CDMA LCD Assembly Replacement: paso 0, imagen 3 de 3
  • Starting at the top right of the device, slide the spudger in between the LCD frame and metal backing plate, which will separate the adhesive as you push.
  • The goal is to separate the adhesive, not to pry the LCD up, so keep the pointed tip of the spudger as low as possible to prevent bending the LCD.
  • If inserting the spudger causes the corner of the LCD to bend up, repeat the steps with the guitar pick to further loosen the adhesive.
Insertar traducción aquí
