Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 42 guías que incluyen este paso.
Traduciendo paso 8
Paso 8
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
