Saltar al contenido principal
Disassembling Asus Transformer Pad TF300
Inglés
Holandés
Paso 2
Disassembling Asus Transformer Pad TF300: paso 0, imagen 1 de 1
  • Start by taking the screws from around the frame off.
  • Then remove the screws from this PCB
  • If you are replacing screen components, skip to step 7
  • Remove the little foam pads from the two connectors on the PCB These are for the digitizer
  • Flip up the releases on the plugs to pull out the ribbon cable. (I will show some more detailed pictures of the same process on other connectors.
Insertar traducción aquí
