Saltar al contenido principal
Disassembling Asus Transformer Pad TF300
Qué necesitas
  1. Disassembling Asus Transformer Pad TF300, Tablet: paso 1, imagen 1 de 2 Disassembling Asus Transformer Pad TF300, Tablet: paso 1, imagen 2 de 2
    • Case back removed from tablet
    • Remove the back with your fingernails, popping it open between the black border, and the plastic backing.
    • Be careful near the buttons and headphone jack.
  2. Disassembling Asus Transformer Pad TF300: paso 2, imagen 1 de 1
    • Start by taking the screws from around the frame off.
    • Then remove the screws from this PCB
    • If you are replacing screen components, skip to step 7
    • Remove the little foam pads from the two connectors on the PCB These are for the digitizer
    • Flip up the releases on the plugs to pull out the ribbon cable. (I will show some more detailed pictures of the same process on other connectors.
  3. Disassembling Asus Transformer Pad TF300: paso 3, imagen 1 de 3 Disassembling Asus Transformer Pad TF300: paso 3, imagen 2 de 3 Disassembling Asus Transformer Pad TF300: paso 3, imagen 3 de 3
    • Note the large copper heatsink. DO NOT pull this off.
    • There are a couple connectors underneath you will have to detach. They have flip up releases, hopefully you can see it.
  4. Disassembling Asus Transformer Pad TF300: paso 4, imagen 1 de 3 Disassembling Asus Transformer Pad TF300: paso 4, imagen 2 de 3 Disassembling Asus Transformer Pad TF300: paso 4, imagen 3 de 3
    • First two are under the copper plate.
    • Next is at the bottom of the tablet.
  5. Disassembling Asus Transformer Pad TF300: paso 5, imagen 1 de 2 Disassembling Asus Transformer Pad TF300: paso 5, imagen 2 de 2
    • Overview
    • Disconnect Sound connector.
    • Unscrew remaining PCBs
    • carefully unplug battery connector (under copper plate)
  6. Disassembling Asus Transformer Pad TF300: paso 6, imagen 1 de 2 Disassembling Asus Transformer Pad TF300: paso 6, imagen 2 de 2
    • You'll have to (CAREFULLY) pop the power button (and maybe volume button) out of place so you do not rip the ribbon cable when removing the PCB. I used a tiny flat-head screwdriver.
  7. Disassembling Asus Transformer Pad TF300: paso 7, imagen 1 de 2 Disassembling Asus Transformer Pad TF300: paso 7, imagen 2 de 2
    • Pic 1 - PCBs removed. Screen assembly and frame only.
    • The screen is only held on with some adhesive so (CAREFULLY) pry them apart. Using a heat gun to loosen the adhesive is HIGHLY recommended to avoid cracking the LCD while separating. The adhesive runs around the entire LCD frame. It's the adhesive that holds the LCD to the digitizer, not the metal frame. Try not to pry against the screen.
    • Pic 2 - Screen assembly only.
    • Carefully peel silver tape off of black tape.
    • Starting at the right (in the picture) peel up the black tape. Be careful! The power ribbon cable for the backlight is hidden under at the left side. See next step for location of connection.
  8. Disassembling Asus Transformer Pad TF300: paso 8, imagen 1 de 3 Disassembling Asus Transformer Pad TF300: paso 8, imagen 2 de 3 Disassembling Asus Transformer Pad TF300: paso 8, imagen 3 de 3
    • Pic 1 - LCD (left) backlight panel (right)
    • Pic 2 - LCD PCB, note backlight connector at right
    • Pic 3 - Backlight panel connector.
  9. Disassembling Asus Transformer Pad TF300: paso 9, imagen 1 de 2 Disassembling Asus Transformer Pad TF300: paso 9, imagen 2 de 2
    • Be careful when removing LCD and when reassembling tablet. not sure when it happened, but apparently I was not careful enough when putting it back together, and this happened. Works perfectly fine otherwise. (Heat gun was not used).
    • It's best to remove all of the adhesive residue from the LCD if you are going to re-use the LCD. Then apply new double sided adhesive (the rubberized kind) for a good "permanent" seal.
    • Be aware there are several different digitizers used in these tablets. If you purchase a replacement digitizer you must get the exact matching part or your digitizer won't work properly.
    • There are also several different revisions of LCD's. Best to get the matching one to avoid any potential problems.
Conclusión
Hope this helped a bit.
I Could not find a guide, so I figured I'd make my own.
17 personas más completaron esta guía.
B0NK3R5
Miembro Desde 11/17/12
566 Reputación
1 Guía escrita
30 comentarios
How can i take off the digitizer from the LCD ? I cant take it off ?
Matthias - Contestar
So you are on step 7?
The digitizer is the whole front panel. The LCD is sandwiched between that and the backlight. (The big white panel)
Around the edge, the backlight sort of clips into the frame. Try using a small blade screwdriver to pop the clips.
B0NK3R5 -
OK i found the problem an done the rest but the tablet didnt start. I think ther is a problem with the cabel´s but i can´t find it. When i push 2 cabels on the backside the screen works but the Touch didn´t work . What is the Problem ? I have buyed this Part
http://www.ebay.de/itm/321001110973?ssPa... . It is the right part for my Asus TF 300 but why zhe touch doesent work
Did you connect the ribbon cables to the main board?
B0NK3R5 -
Yes i connected the ribbon cabels to the Mainboard. I think one cabel is damaged . It is possibel that the cabels from the digitizer are not working , because the LCD is working when i push on one connector but the digitizer doesnt work .
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 18
Ultimos 30 días: 58
Todo El Tiempo: 86,501
