Saltar al contenido principal
iPod Touch 5th Generation Front Panel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 21 guías que incluyen este paso.
Inglés
Holandés
Paso 5
iPod Touch 5th Generation Front Panel Replacement: paso 0, imagen 1 de 3 iPod Touch 5th Generation Front Panel Replacement: paso 0, imagen 2 de 3 iPod Touch 5th Generation Front Panel Replacement: paso 0, imagen 3 de 3
  • In the following steps, you will be loosening and freeing the plastic frame that surrounds the screen. It is connected to the rear case with several clips.
  • Starting at the top right of the device, insert a plastic opening tool into the gap between the plastic frame and the aluminum rear case.
  • Slide the tool down this crack, loosening the frame from the case.
Insertar traducción aquí
