Saltar al contenido principal
iPod Touch 5th Generation Front Panel Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 21 guías que incluyen este paso.
Inglés
Holandés
Paso 4
iPod Touch 5th Generation Front Panel Replacement: paso 0, imagen 1 de 3 iPod Touch 5th Generation Front Panel Replacement: paso 0, imagen 2 de 3 iPod Touch 5th Generation Front Panel Replacement: paso 0, imagen 3 de 3
  • Hold the iPod firmly against a table or bench.
  • Place your thumb and index finger over the lower corners of the display to stop the display from opening too far when the adhesive breaks.
  • Lift the suction cup up and back toward the top of the iPod. Be patient, and pull with firm, constant force until the adhesive breaks and the display comes up from the rear case.
  • It may be necessary to use a heat gun to soften the adhesive (especially in cooler climates). If you can pry the screen apart, and the adhesive is still sticking and pulling apart like cheese topping on a pizza, you can slide a thin razor blade in and gently cut the adhesive.
  • After the display begins to lift from the rear case, be careful not to lift more than about an inch—a fragile plastic frame still connects the display assembly to the rear case.
Insertar traducción aquí
