Saltar al contenido principal
Samsung Galaxy A3 (2017) Vervanging van het scherm
Inglés
Holandés
Paso 4
Samsung Galaxy A3 (2017) Display Replacement: paso 0, imagen 1 de 2 Samsung Galaxy A3 (2017) Display Replacement: paso 0, imagen 2 de 2
  • The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
  • After cutting the adhesive on all sides of the phone, insert a plastic card beneath the display assembly to loosen any remaining adhesive behind it.
De flexkabel van het scherm bevindt zich direct achter de volumeknoppen en kunnen dus in de weg van je plectrum komen te zitten.
Steek, nadat je de lijm aan alle kanten hebt door weten te snijden, een plastic kaart onder de schermmodule om de resterende lijm erachter ook los te maken.
[* icon_caution] The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
-[* black] After cutting the adhesive on all sides of the phone, insert a plastic card beneath the display assembly to loosen any remaining adhesive behind it.
+[* black] After cutting the adhesive on all sides of the phone, insert a [product|IF145-101|plastic card] beneath the display assembly to loosen any remaining adhesive behind it.
