Saltar al contenido principal
Reemplazo de pantalla del Samsung Galaxy A3 (2017)
Inglés
Español
Paso 4
Samsung Galaxy A3 (2017) Display Replacement: paso 0, imagen 1 de 2 Samsung Galaxy A3 (2017) Display Replacement: paso 0, imagen 2 de 2
  • The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
  • After cutting the adhesive on all sides of the phone, insert a plastic card beneath the display assembly to loosen any remaining adhesive behind it.
El cable flexible de la pantalla está ubicado justo detrás de los botones del volumen y podría interferir con tu herramienta de corte.
Luego de cortar el adhesivo en todos los lados del teléfono, inserta una tarjeta de plástico por debajo del ensamblaje de pantalla para aflojar cualquier adhesivo restante.
[* icon_caution] The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
-[* black] After cutting the adhesive on all sides of the phone, insert a plastic card beneath the display assembly to loosen any remaining adhesive behind it.
+[* black] After cutting the adhesive on all sides of the phone, insert a [product|IF145-101|plastic card] beneath the display assembly to loosen any remaining adhesive behind it.
