Introducción
See what's going on with a new iPod Nano 5th Generation LCD.
Insert an iPod opening tool between the outer case and top bezel near the screen.
Lifting up on the iPod opening tool, gently pry the top panel off of the device.
Use a heat gun to soften the adhesive underneath the plastic bezel at the bottom of the iPod.
Use a plastic opening tool to pry the bezel from the case of the iPod and remove it.
Use a heat gun to soften the adhesive underneath the camera/microphone cover.
Pry the camera/microphone cover off the case with a metal spudger and remove it.
Use an iPod opening tool to pry the display connector off its socket on the logic board.
30 personas más completaron esta guía.
8 comentarios
Re-assembly is kind of the reverse of disassembly, but replacing some of the glue may be required, particularly for the camera/mic cover. Sliding the logic board into the housing is an exercise in considerable care - the display ribbon, the speaker ribbon, various bits of yellow tape, all can snag on the lugs around the clickwheel hole, or the camera/mic holes.
what type of glue would you recommend?
Help my ribbon for hold switch fell off!!! Will it still work without the hold switch connected?
I used a cigarette lighter instead of heat gun and worked like a charm.
Sadly my ipod was full of glue and it was not possible to replace the display and broke it. :-(
