Introducción
Your iPod's motherboard controls just about everything on the iPod.
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should easily open.
Grasp the hard drive with one hand and carefully disconnect the orange ribbon cable from the hard drive using your other hand.
Peel up the black adhesive strip covering the hard drive ribbon cable.
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Slide the orange click wheel ribbon cable out of its connector. You must unlock this connector before sliding the ribbon cable out. The locking mechanism is on the opposite side of where the cable is inserted - it swivels upwards 90 degrees. Use a plastic spudger to lift the locking mechanism.
27 personas más completaron esta guía.
3 comentarios
what's the differece between 20G logic board and 40G logic board? I have changed hard drive into CF card and now I have to change logic board..
So there’s the difference between 20gb and 40gb logic board? I’ve changed 20gb HDD to new 40gb HDD and now Can't get to work my ipod! So what to do?
No idea if anyone will respond to this but here goes: Okay so I just want to know if you can repair the part where you attach the screen cable to the logic board, that part suddenly came off and was wondering if there’s a way to reattach that part back onto the logic board so the display can show up??
