Saltar al contenido principal
iPhone XS Max Display Assembly Replacement
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. iPhone XS Max Display Assembly Replacement, Display Assembly: paso 1, imagen 1 de 2 iPhone XS Max Display Assembly Replacement, Display Assembly: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
    • Two 1.1 mm screws
    • One 1.5 mm screw
    • One 3.7 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  2. iPhone XS Max Display Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the bracket.
    • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  3. iPhone XS Max Display Assembly Replacement: paso 3, imagen 1 de 2 iPhone XS Max Display Assembly Replacement: paso 3, imagen 2 de 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  4. iPhone XS Max Display Assembly Replacement: paso 4, imagen 1 de 2 iPhone XS Max Display Assembly Replacement: paso 4, imagen 2 de 2
    • Remove the three Y000 screws securing the display connector bracket:
    • Two 1.5 mm screws
    • One 1.1 mm screw
  5. iPhone XS Max Display Assembly Replacement: paso 5, imagen 1 de 1
  6. iPhone XS Max Display Assembly Replacement: paso 6, imagen 1 de 2 iPhone XS Max Display Assembly Replacement: paso 6, imagen 2 de 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  7. iPhone XS Max Display Assembly Replacement: paso 7, imagen 1 de 2 iPhone XS Max Display Assembly Replacement: paso 7, imagen 2 de 2
    • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. iPhone XS Max Display Assembly Replacement: paso 8, imagen 1 de 2 iPhone XS Max Display Assembly Replacement: paso 8, imagen 2 de 2
    • Use a spudger or fingernail to pry the digitizer cable connector up from its socket.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  9. iPhone XS Max Display Assembly Replacement: paso 9, imagen 1 de 3 iPhone XS Max Display Assembly Replacement: paso 9, imagen 2 de 3 iPhone XS Max Display Assembly Replacement: paso 9, imagen 3 de 3
    • The front panel sensor assembly flex cable is lightly adhered in place.
    • Carefully lift the cable until the adhesive separates.
  10. iPhone XS Max Display Assembly Replacement: paso 10, imagen 1 de 1
Conclusión
Una persona más ha completado esta guía.
Jeff Suovanen
Miembro Desde 08/06/13
428,113 Reputación
259 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 409
